$55 Dellorto 16.16 SHA and filter
lightly used... switched to a 15mm phbg. bought the 16 sha brand new from treats about a month ago.
if you like drillin' holes and such and are crafty then this 16 sha is for you. it will not idle on a larger kit (at least the one I had it on, so I cut the slide and it would idle). I will include a new slide for your cutting pleasure.
I will include a lightly used SHA filter for it too, yup!
it's the lever choke version too. if you know what jet you need I most likely have it and can include it for ya. I also replaced the clamp bolt with an allen head bolt.
$55 SHIPPED for carb and air filter
this is the air filter: https://www.treatland.tv/ProductDetails.asp?ProductCode=dellorto-air-filter-G1-60mm
Re: $55 Dellorto 16.16 SHA and filter
email only please
