WTB: Dellorto Carb
You still got that old dellorto 15.15 carb kickin around in your basement? Maybe it needs to be cleaned and loved a little before it goes back on a ped? You should sell it to me! Looking for a solid carb to upgrade my tomos from the stock 14.12.
WTB: Dellorto Carb
do it!
Re: WTB: Dellorto Carb
I have a 16.16 with lever choke that I am not using. Bought it for a Tomos build and ran it a couple times on the motor before removing and going in another direction with it. I have since broken the throttle bendy on the replacement and used the bendy and plastic from the 16.16. The plastic is easily replaced. Carb has very little run time. If you want it I will sell for 45 shipped to RI.
I have a 14-12 I took the tube out of and drilled to 15~ mm just swap everythin from old to new an bolt it up 30$ shipped. Just the body no top slide ect
