Intake for yer cylinder, not your junk! Well maybe your junk...
22mm Inner Diameter//39mm from the insides of each mounting hole.
22.5mm Inner Diameter//42mm from the insides of each mounting hole.
The mounting hole width on both ends is wider than the Korado cylinder, but has plenty of room to make a shorter length between mounting holes.
Pictures shown are mocked up on a Korado cylinder.
$25 shipped. Paypal is the address above. Thanks!
