FS: Motobecane Wonders
Weak-Ends Tj /
I bumped up a notch from Av7 to Av10.
Items:
Av7 crank- new bearings, needle bearing, threads on both ends are perfect.
Av7 Parmakit- Installed never ran, no gaskets, piston ramped to compensate for offset ports.
Av7 Cases- matched to the parmakit, comes with studs, find some case bolts, seals may be good..probly installed backwards..ha.
Av7 12v points setup- new condensor, new points, comes with flywheel, cam, coils back plate.
Email offers.
