Looking for Motobecane pedals
I have the crank arm, but the actual pedals are missing.
Does anyone have any pretty cheap?
Thanks a ton.
Re: Looking for Motobecane pedals
Andrew Squiggman /
put on some bike pedals?
Will that work?
I think bicycles use two different sizes so you will want to bring in one of the crank arms and try out some pedals, but they should work, yeah.
Alrighty, I will check into that.
Thanks! :)
I've got some spare stockers, in very used condition, if you need.
Go to walmart and buy the threaded nut that adapts bicycle pedals to your cranks..its like $15 for the pedals and adapters..
bicycle pedlas are either 1/2" or 9/16". 1/2" is common on jr or kids bikes. your pedals are most likely 9/16" but it would still be smart to double check.
when you know for sure you can look online for new cheap deals:
ebay
amazon
danscomp.com
Mobys and Derbis, i think, use french thread pedals. Derbi's definitely do.
"Harris Cyclery on the subject":http://www.sheldonbrown.com/harris/french.html
French-thread Pedals
Most French bikes sold in the U.S. used standard thread pedals:
9/16" x 20 TPI (14.29 mm x 1.27)
But older bikes made for the French market used a slightly smaller thread:
14 mm x 1.25 (.551" x 20.32 TPI)
If your cranks are made for standard-thread pedals, a French-thread pedals will fit in, but be very loose and will be unusable. It is not possible to put a standard pedal into a French crank without considerable violence.
It is possible to re-tap French cranks to take standard pedals. Use standard 9/16" x 20 taps.
Link won't post.
1977 mopeds shows them being in stock.
Also, looking for the pedal arm and pedal for a 50V. one is there, but the other one is missing.
