FS: Magnum & Maxi parts Used Kits, ECT..
Andre Hummer /
Shipping varies $5 to $10 depending where you are
Everything is Best Offers
1977 Magnum Parts:
Mag Seat (one bolt snapped off) - $50
Mag Side Covers (Painted Black) - $30
Mag XK Fork (primer paint) - $40
Maxi Parts:
Stock Forks - $20
Kits:
70cc Kstar/DMP Cylinder (has thin layer of teflon crank gunk in the cylinder but none in the transfers, needs to light honed out) piston was cleaned up, 19mm intake, 70cc Hi comp head
- $90
64cc Polini Cylinder Type B
(at least 300 miles to it, Never Seized)
I took it apart recently and noticed some high spots on the piston so I cleaned those up.
Ring land gas porting on the piston.
4 pedal Reeds w/ 19mm intake & new head gasket
- $200
Heads:
50cc Hi comp Head (Fins cut to fit the 4 pedal Polini) - $15
50cc Hi comp Head (Not Cut) - $15
50cc Stock Head (Old Style) - $15
50cc Stock Head (New Style, Sanded the tabs flush, Fins Cut) - $15
50cc Stock Head (New Style) - $15
70cc Hi Comp Head - $15
70cc Hi Comp Head Type II - $15
Carburetor:
19mm Dellorto PHBG AS (Clamp Style)
E12 Air Filter
Au Atomizer, 40 Slide, W7 Needle
50 Idle / 100 Main (I have tons more jets just don't know all the #'s)
- $100
Extras:
Boss Pipe exhaust (side was grinded a bit to reach exhaust bolts) - $30
Gloss Black Headlight Housing (chrome Rim) - $10
More Fenders Chrome (front and back for Magnum) - $20
That's all I can think of for now I have some electrical parts little things here and there, I'll post more with pics after it's all sorted
Re: FS: Magnum & Maxi parts Used Kits, ECT..
I'll take the kstar kit
emailed
interested in side covers email me with pics plzzz!
Andre Hummer /
I should have said this before the emails
All parts will be boxed tonight, I'll be weighing everything tmrw morning so that I'll have shipping fees
*Parts on hold till tmrw:
Seat
Kstar Setup
50cc Hi Comp Head (uncut)
70cc Type II Head
Front Fender
I'll have it all ready tomorrow asap
pic of headlight housing?
emailed if the uncut 50 hi head falls thru. Would the cut 50 hi head work with a stock setup still?
Andre Hummer /
Here's the pics I have saved from earlier
Headlight:
Side Covers:
Mag Fork:
50cc Hi Comp Head (fins cut for the polini setup)
should work fine with the stock setup, it would just look like its got a hair cut
ill take that boss pipe
-Quinn
ɯɐpɐ ʞunʞs /
Pics of the maxi forks?
I'll take the side covers i emailed you back
paypal sent!!!
emailed for headlight, and pipe is not taken!
if, not is
Are the 70cc heads from Treats or from a brand name kit?
E-Mail me if pipe is available, Thanks Jerry
Andre Hummer /
On Hold or Sold
Kstar Setup
- Sold
70cc Type II Head
Front Fender
Headlight
- On Hold (boxed up)
19mm Dellorto
Boss Pipe
(Boxed up Ready to ship, just waiting for the car to get back to me)
64cc Polini Setup
- On Hold
Magnum Side Covers
- On Hold (waiting for the box)
Magnum Seat
The rest is still available
Andre Hummer /
The hi comp heads are the Treats style ones, the Stock heads are the Puch named brand ones
Ok...Are they flush or warped? (I've heard more than one person having air leaks from these)
Andre Hummer /
Really? I've never experienced that before, usually touque the bolts down in the X pattern little by little to not cause a warp effect
Andre Hummer /
Boss Pipe - Sold
Magnum Side Covers - Sold
Magnum Seat
Polini kit available?
Andre Hummer /
Polini is still on hold to a friend, just waiting for him to pay up grr
Carb is no longer on hold, up for sale again.
Included Main Jets: 100, 98, 95, 92, & 89
- Best Offer
70cc Type II Head
Front Fender
Headlight
