carb troubles 78 puch maxi
I have a 1978 1.5hp with a 12mm Bing carb on it. It will run for a minute or two then it will die out and quit. Has long as I hold down the black button on the side of the carb the one that allows gas to flow into the carb it will run but gas runs right out of the carb. I let go of the button the engine quits. Any body have any ideas or know where I can buy a 12mm bing carb? Thanks Ken
Sounds like it needs a good cleaning bro
Re: carb troubles 78 puch maxi
clean it and try raising your needle, there is probably a good break down in the wiki. its super easy.
ok
dan henkleman /
Adjust the float. Black button just pushes the float down, allowing fuel to flow in. Bend the metal bracket on to float to adjust it.
Luke “Funkenet” Hosfield /
I got one if you need it still.
How much + shipping to Mi 49046
your not far from kalamazoo and grand rapids. get ahold of us or the decons. im sure someone from either group would give you a hand and teach you a thing or two.
I do not know who us is or the decons group. Could you please tell me who that is and how to get ahold of them.
