WTB: Korado Clutch bell and main drive
- Summerai - Drew /
Silly me forgot regular e50 guts
wont work in a korado case.
I just need the reverse toothed
main drive gear with the bearing
if you still have it and the clutch
bell and bushing.
Re: WTB: Korado Clutch bell and main drive
Why won't they work? That's what Ive been using in my korado cases...
- Summerai - Drew /
Not sure what kind of Korado case you have
but mine will only accept a main gear with
only one bearing, not two like your typical
e50 gear. And from what I understand the
style with one bearing as reversed teeth
than that on a normal e50. Same with the
clutch bell. Check the wiki.
- Summerai - Drew /
I had no idea some e50s had a one
bearing main drive. From the way I
understand it is that all main drive
gears are interchangeable. Just
remove one of the bearings. I didn't
Know this.
Thread closed.
yeah ive been using regular e50 guts in my 3 bearing korado cases for a while, lots of hard miles and no issues, you should be fine....
yea just pull off the one bearing.
i run korado stuff in an regular e50.. i just add the bearing.
