motobecane parts for sale
very nice maybe new av88/89 pistons-$10 shipped
50v piston/cylinder I think a "c" -$30 shipped
new 50v coil w/ fins-$10 shipped
50v head w/ decomp-$10 shipped
nos moby motor return springs-$7 shipped
nos moby master switch horn/kill switch-$8 shipped
nos moby speedo drive $8 shipped
av88.89 square/rectangle headlight reflector lense $20 shipped
Lots of little tiny weird Moby nos bits-spacers,springs,gurtner stuff,caps,plugs,speedo deleest.........
Re: motobecane parts for sale
I will be emailing you on some of that...
50v head mentioned above has a new decomp
white plastic tool box knobs-$8 shipped per pair
ar-12 gurtner w/ airfilter $12 shipped
7662 Gurtner w/ airfilter $10 shipped
50v tailight lense $7 shipped
round av89 headlight bucket w/ speedo $20 shipped
3 ball variator w/ no clutch cover plate thing that goes on the front $20 shipped
Lots od spacers
have the spacers that push into the motor mount on the head that the bolt rides one (nos) $8 shipped per pair
square av88 headlight bucket, decent shape, no speedo $15 shipped
I can drop prices a bit if you order more than one item.
I will email you also about the
could you show a pic. of that rectangle headlight lens
Any grey OEM-style brake cables?
trucker rick, it is not the actual lense it is the shiny reflector piece inside, I will dig around for a lense.
Mick I do have oem gray cable housing for sure, what ends to the brake cables have?
Reb-emailed
Foun needle bearings wrist pins and new or nwish av89/88 pistons too
New 50v coil with fins.
would this be the ignition coil in the magneto?
I need all the 12v stator ignition coils I can get.
Paulvolio I meant the external ignition coil but I have a bunch of nos internal ignition coils, Reb sent me a chart to identify them
Declan - the Moby brake cables have liberty-bell shaped lead blobs at the control end, and the brake end has nothing (to be used with a knarp).
"C" Cylinder SOLD
NOS moby throttle assembly $25 shipped
New chrome moby brake levers $10 shipped per pair
6v lighting and ignition coils $10 shipped
12v novi 50v lighting and ignition coils $12 shipped per pair. i lighting one ignition same w/ the 6v ones above but $10
moby pedals and pegs used-$12 shipped
Got a working 12v stator ?
Speedo drive means the cable for the speedo, not the actual speedo, right?
If you have a speedometer, let's talk.
send me a pic of the part you need aaron
I have some speedos that are new, all 20mph versions though, also have a round one that is new I believe but that may be vdo.
What's vdo?
Also, yeah, 20mph would be possibly the only thing less useful than my "minimalist" (read: faded to an almost even light beige) speedo.
emailing about the variator tonight
new av7 case bare $20 shipped
i'll email you about the pegs.
I may be looking for a speedo drive, the part that is turned by the wheel, for my friend. I will know for sure tomorrow.
when you say pegs do you mean the pedal arms? If so/not do you have the arms?
emailed about the variator
i am definitly interested in a speedometer drive, and cable if you have one. my friends speedometer drive has a bad bearing and broke the cable.
