Lathe bored bing bodies and 50cc hi comp head
getting rid of some junk thats accumulated.
5 bing bodies bored out on a lathe
These are all bored on a lathe using successive reamers to give a smooth finish. They are finished with a 5 deg tapered reamer to give a venturii effect with slightly larger mouth diameter.
4 are bored to 5/8" = 15.8 mm
2 of them turned out perfect. smooth finish. - $25 each shipped
2 of them ended up with some chatter on the final taper reaming, they have a weird 'rifled' pattern on the inside. Maybe its better, maybe its worse, who knows! you test and find out for $20.
The last carb is only bored to 9/16 for some reason... also taper reamed- $20
This is for JUST THE BODIES. they have been precisely machined and finished, ready to install all the guts from your carb. They do come with the tickler buttons installed.
50cc 'treats' hi-comp head, kinda dirty, good shape- $15 shipped.
Re: Lathe bored bing bodies and 50cc hi comp head
oh yeah, email is in the profile, probably quicker than just posting to this thread, thanks!
emailed about the $25 body
just sent you email for the hi head ...
email in profile was returned, got a good email???
hi comp head and one of the bings is gone, 4 left.
email me motzingg at gmail dot com
Emailed about the Clean Bing.
-Honest
3 bing bodies left
the 14.9 mm one and the two with the 'rifled' pattern
hell, i should probably call them 'vortex bings' and charge $50 for them, these people think it will turn your carb into a 'power packed vortex'
guess mike isn't taking the other smooth bored bing, back on the market!
Is a new atomatizer the only thing I need I dont have on my old bing?
shoot, didn't see this today, its just the body, no guts, needs to be swapped from another carb.
Yea i know. But I've seen the bigger bings have a different atomatizor or jet holder or whatever the hell you call it but everything else is the same, which I have because I have a 12 bing
These all came from me so i have most of the guts.
If needed email me.
still got some of these, the two rifled-bored ones...
$15 each shipped... way easier than trying to drill or dremel your own
c'mon, you know you're curious. vortex intake power!
Andrew Squiggman /
Emailed
Andrew Squiggman /
oops. wrong address. youve got mail
all of these are sold
thanks everyone!
