Lathe bored bing bodies and 50cc hi comp head
Graham Motzing /
getting rid of some junk thats accumulated.
5 bing bodies bored out on a lathe
These are all bored on a lathe using successive reamers to give a smooth finish. They are finished with a 5 deg tapered reamer to give a venturii effect with slightly larger mouth diameter.
4 are bored to 5/8" = 15.8 mm
2 of them turned out perfect. smooth finish. - $25 each shipped
2 of them ended up with some chatter on the final taper reaming, they have a weird 'rifled' pattern on the inside. Maybe its better, maybe its worse, who knows! you test and find out for $20.
The last carb is only bored to 9/16 for some reason... also taper reamed- $20
This is for JUST THE BODIES. they have been precisely machined and finished, ready to install all the guts from your carb. They do come with the tickler buttons installed.
50cc 'treats' hi-comp head, kinda dirty, good shape- $15 shipped.
  Lathe bored bing bodies and 50cc hi comp headTopic by: Graham Motzing Graham Motzing 02/12/11 11:08PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/12/11 11:11PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: The Dude The Dude 02/13/11 12:13AM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: K Dub K Dub 02/13/11 12:21AM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: The Dude The Dude 02/13/11 12:23AM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/13/11 12:08PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Honest Mike Honest Mike 02/13/11 02:55PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/13/11 03:54PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/13/11 04:01PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: The Dude The Dude 02/13/11 04:49PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/14/11 07:35PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: The Dude The Dude 02/14/11 10:59PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Seb B Seb B 02/15/11 12:24PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/16/11 12:32AM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/16/11 04:42PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Andrew Squiggman Andrew Squiggman 02/16/11 06:47PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Andrew Squiggman Andrew Squiggman 02/16/11 08:47PM
  Re: Lathe bored bing bodies and 50cc hi comp headRe: Graham Motzing Graham Motzing 02/16/11 09:10PM
