Feeler: Clip on bars
I'm going to build a small run of clip on handlebars. Dimensions can be found here break>
28mm clamp will fit regular EBR forks, and some others. Ill consider making different size clamps if there is interest. Bolts are M8x1.0 x 25.
Cost will be $55 shipped once they are done, or $40 shipped for the first 6 pre-orders. Will ship no later than 2 weeks after pre-orders fill up.
Contact cmfgparts@gmail.com
Re: Feeler: Clip on bars
Hella Dankmeme, III /
i have seen these in person, and I have to be honest, it moved a little.
† CH∆D † /
you should put alittle downward slope on em? Good deal though
I can make the pre-orders at custom angles.
15 degree down-sweep
Knurl the inside surface
Or flute it.
O I got it set screw.
If you make some with a 30mm I.D. I would probably pick them up. I still haven't figured out how I'm gonna set up my clip ons.
I can make you a set with 30mm ID. Just let me know what you want.
also, instead of having just the smooth tube on the forks, you should make little teeth on the bars, or get some high friction foam material to put in between them
I rode these for 3 months without them slipping once. This isn't a new design, it has been used for years on motorcycles and bicycles.
These are nice! Totally worth the price it appears. Good welds.
These are super cool. Only a month too late for me though, as I already bought the treats clipons.
