Need Morini M0 piston bushings
Need piston pin bushings for Morin piston port. Any thing else fit?
Re: Need Morini M0 piston bushings
Measure and look on treats and 1977. I know the ID is 12mm
My Chinese micrometer measures the piston pin hole in the rod at 12MM ID, 15MM OD and 13MM wide. The Puch con rod bushing measures 14MM OD.
