******I have been checking Ebay, and Honda dealerships, and scrap yards, and moped treats.******
I'm looking to buy a Rear brake cable for 1979 PA50II if anyone has one lying around. Thanks
v/r
Jeremy
v/r
Jeremy
did you check ebay, honda dealerships, or moped treats?
After working on my hobbit(s) for some time, I don't think you really need the special rear brake cable. With a standard adjustable long rear cable, possibly some new knarps, and some ingenuity, you can almost certainly replace it. You might have to bore out the hole that the threaded end of the stock cable runs through a little. Run the threaded end of the replacement cable through that and secure it using the two flat nuts. I don't remember exactly what the control end looks like, but if you have knarps for both ends and trim your housing correctly, I think it's more than possible and a lot cheaper.
ebay.be
camino rear brake cable
Measure the length of the cable - this should adapt to the bike
