Wtb/trade 4stock a55 jug/intake/carb/piston... Etc
I'm looking to see how much a used a55 piston, cylinder,intake and carb ,crank needle bearing would run me. I have some things to trade like a e50 without clutch stator flywheel , idk if I have clutch plate or the little spring that holds the clutch plate. Engine probably needs a rebuild but does turn over. I also have a puch boss pipe im not sure if im gettig rid of . It is in ok condition the rivets in the end are comming out.. I would prefer not to get rid of the pipe so maybe s trade for the Engine for those parts and some cash . If find anything else I'll let u know
Re: Wtb/trade 4stock a55 jug/intake/carb/piston...
I also have a stock a35 pipe and a 14 mm bing intake and maybe carb if I can find it which I probably can
I also have puch maxi nostalgia side covers. And stock a35 sha carb. I believe it's a 14.12
Emailed u
bummmp
Why do you want an a55 cylinder?
I could probably hook you up with a phva for cheap hit me up.
could u email me punk maybe we could trade?
