WTB: throttle that can pull a 28mm
My stock cobra throttle just ain't cutting it anymore. Need something that can pull a 28mm carb wide open. This might be something I need to go to a dirtbike shop for, but I thought I would check here first. I looked on treats but the only one that had a measurement said it had 26mm of pull. Not good enough.
Re: WTB: throttle that can pull a 28mm
new lusito throttle will measure and let you know
You sure the Motion Pro can't do 28? I'm using what feels like half the action and opening a 21mm PHBG.
Woah. Didn't see the second page on treats. Magura throttle can pull 50mm. Which is a lot. If I don't score one from one of you fine people I will probably go with that.
