Vintage 1977 Motobecane Moby Parts Available
I know the picture is not great, but its tight in my basement. If you can think of anything you might want off this bike, let me know.
There is no carb but there is a seized 6v motor without wire leaving ignition coil (weird, I know. Someone must have needed it since the motor was seized).
Anyways, let me know and ill send whatever you need.
Re: Vintage 1977 Motobecane Moby Parts Available
Thumb screws for the side covers ?
The lower chrome saddlebag rails ?
the little adjusters that keep the front fender on at the wheel ?
Seat cover or complete seat ?
Is the crank okay?
I will take the engine but all I need is the crankshaft.
If you can get the variator and stator off I don't need it.
Crank is probably screwed anyway.
ive got good cranks paul. could use that carb back soon too...
What does that 19 need so I can get to ordering stuff?
No thumb screws, but the seat is definitely available.
Adjusters that keep the front fender on at the wheel? If those are the same thing that keeps the cable for the breaks on, then yes. If thats not it, descripe to me what are talking about. Im sure it has them.
Its a dimoby, does that change anything?
