Boysen RAD vavle reedvalve $25 shipped!!!
bought for a custom intake manifold and i ended up going with a bigger reedcage...this is designed for a 50-70cc dirtbike..very nice, these are one of the most expensive reed setups you can buy, they retail for more than the v-force....$25 shipped
Re: Boysen RAD vavle reedvalve $25 shipped!!!
wounder if i could make that fit a m48 ?? how far apart are the holes?
campeona del mundo /
^^^not worth all the work it would take^^^
i will measure and get back to you, wont be back at the shop till saturday though...the holes are narrower than gila but it is way deeper, so if i had to guess it probably wouldn't fit a bat
Throw that last pic up with measurements!
i'm also interested in dimension bobby
here are the dimensions
the holes are 56mm center to center on the top and bottom
and 47mm c-c on the sides of it.. the V section is 45mm deep
anyone want to unleash the power?
$20shipped, anyone..
I have an intake-less Motobecane Mobylette 50 with a "70cc" Parmakit.<br>
<br>
would you be able to make an intake for that if i supplied diagrams that detail whats needed to mount the reed cage to the engine, mount my Carb to reed cage, etc?<br>
<br>
I can do the final cuts for engine and carb mounts, i just need flanges at the correct angles. The hard part will be cramming it all into the tiny hole between the side panels...
sooo maybe i have an AV7, which means adding reeds to a piston port engine...kinda pointless...disregard everything i said previously
