This is NON running 1980 Puegeot 102sp.
I bought this bad boy last summer and planned to restore it to its full glory (if not full glory, at least partial glory to where i could jump through a fiery hoop on it). This has not happened, I just have not had the time, nor hoop.
The Good:
-Moped is totally complete. I have all the parts, not all attached...but all there. ...sans some of the superficial plastic side pieces.
-I took the time, money, and energy to break down the engine, clean it and refit it with new gaskets. I even did electrolysis on the crank to remove some rusty buildup.
-Carb is immaculate, could have given birth to Christ its so immaculate.
-I scoured the internet for manuals and diagrams and things of that nature (specifically for the 102sp), so I have some really good, original moped wisdom in book form.
-I have around 400 pictures of the moped and its pieces in various states of completeness as I took it apart to clean. I'm willing to give these out as reference.
-I have a brand new spark plug and drive belt to go with the moped (plus all the spanking new gaskets that are already installed).
The Bad:
-Gas tank is rusty. So you'll have to de-rust it, either chemically or....well probably chemically. I can point you in the direction of some help, but if you're considering buying this moped you probably already know what's up.
-There's a bit of rust on the outside of the moped, not too much and not particularly noticeable but it's there.
-It's not all put together, the engine, manifold and carb are off as well as the throttle and those cables (which I have). Also the magneto is apart, all there, but not put together. But as I was cleaning and adjusting I needed to remove some parts. I could put some of the stuff back on if you wanted...
The Ugly:
-Mostly the rusty gas tank. That can be taken care of fairly easily according to everyone I've talked to and everything I read. Its just takes some well ventilated space and some chemicals. You could also try electrolyses. Which freaking works like a charm, by the way.
I'm asking for $450 (or best offer). Also this deal is a Pick Up Only.
If you have any questions or want to see more pictures, let me know and I'll get that right out to you.
Word up. Thanks for looking.
