WTB Z-type italian rear sprocket
Preferably small
Re: WTB Z-type italian rear sprocket
tomos? 31? elonggate the hole.. ?
I though about that but I really dont want it off center at all. I dont trust myself. I should just do it or have it shopped.
also Derbi sprockets?
I had a sprocket.. cut and fitted for 40 at the local machine shop.. shop so old runs off everything off belts.. 3ft around and 20 ft long lathes they has.. 4 jaw is going to be needed.
4 jaw isn't necessarily needed, depends on the number of teeth. A 36 for example will work perfect in a 3 jaw. I would make 36t if I had them made.
yes salty I know that.
I was stating what they used bud.
That is all.
z sprockets are still made today.
I can order them but.. were talking not 1 or 2.. more like 50-100 of each unit.
1 more question...
Are you looking for a flat or dished.
What is the spacing on the holes I will look in my catalog.. if you would like.
what rim is this for?
bring it to me and we will look in the pile
I'm gonna jump on this but i'm looking for a 40-44 tooth to mod for a tomos wheel
Old school tt mag ? is the same bolt pattern as the italian z-sprockets. They change at some point. I had the center cut ont he lathe so it would be center on my wheel. I do not think I had to elonggate much. I thinking the number for .280 I had removed from the center been a long time.
italian hub is smaller then the tomos, slot the bolt holes, feeler gague to center a tomos 28 on the italian hub.
you'll need to enlarge an italian gear to fit on the tomos hub i bet.
centering the tomos 28t on a garelli wheel
I was talking about tomos mag and using a minarelli z42 sprocket. I didn't want any hop hopping on the chain glenn.
machine shop is the only way to go imo. No guessing.
I have two NOS Z-50`s and one very good used Z-32.
Ike
