FS: Hobbit Athena PROS ONLY
Disclaimer: This kit is not for everyone. It requires custom modifications to cases to work. Please read on if youre up for some experimentation.
First off, this kit is the best hobbit kit... period. The most powerful, most revs, and amazing quality.
Second, this kit powered my hobbit to the honest low 60 mph area for 2 seasons and over 3000 miles on both coasts. It was never seized. Sarah blew a hole in the piston after a set of points took a shit in Austin, but it has a new piston which i waited 6 months to get, and it has less than 1000 miles. Consistently and reliably the fastest hobbit ever on these shores?
My simple setup was this kit was this: 30 yr old points, motomatic n8p, derbi 6 weight vario, dio 4 pedal and 24mik. dio2ks
I modified the stock head by hand with a dremel to give it clearance for the piston. This method proves to be crude, yet successful (also ask Matt Aberle) but it can make the headgasket a weak link if you decide to keep the decomp. I am a hobbit purist, so i always keep the decomp. This kit will require a new ATHENA headgasket.
The kit transfers have been opened up substantially and the transfer splitters have been thinned and smoothed. Extra material will need to be added to stock cases and transfers will need to be widened to make the most of this setup. I used JB Weld on the cases and it seemed to do ok, but i did A LOT of prep work and was very patient. It might bolt up to a stock case without mod, but i would not recommend it. A custom basegasket will need to be cut.
I will include the stock head i cut to make it work, but ideally you'd ask graham from the cranks to cut you a custom one, but i do not recommend having any type of high comp math'd out squishband. All hobbit kits are low comp and run cold and they are fine with it.
Devin Biek and i spent many many hours cleaning this kit up. thinning out walls, examining all the flow areas and making them as smooth as possible in the transitions. You will see port work at its finest with this kit. All extra "flashing" from the cast has been removed and cleaned up. The exhaust outlet was cleaned up, opened up and smoothed to a mirror finish. This setup is designed to flow seamlessly and matched into a Motomatic 24mm header with a custom exhaust gasket that does not crush into the port creating a bottleneck. The motomatic is the only pipe i suggest running with this kit. not much of the port timing has been changed. maybe 1-1.5mm total raising/lowering.
There are bronze sleeves in the stud holes, resizing them to 6mm making the kit perfectly centered on all the studs.
This kit is awesome but its a challenge. I managed to not have a lot of maintenance but i really put a lot of time and heart into the setup and always was thinking ahead of potential failures and going the extra mile.
$180 shipped is the price. Comes with clean low milage piston.
Thanks!
if you read carefully, i gave away alot of my little secrets for a consistent and powerful build.
  FS: Hobbit Athena PROS ONLYTopic by: peter peter 11/16/10 01:28PM
  Re: FS: Hobbit Athena PROS ONLYRe: ZEROS Brian ZEROS Brian 11/16/10 01:33PM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/16/10 01:44PM
  Re: FS: Hobbit Athena PROS ONLYRe: -Riprips- ** -Riprips- ** 11/16/10 02:17PM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/16/10 02:22PM
  Re: FS: Hobbit Athena PROS ONLYRe: -Riprips- ** -Riprips- ** 11/16/10 03:19PM
  Re: FS: Hobbit Athena PROS ONLYRe: mattology - mattology - 11/16/10 04:08PM
  Re: FS: Hobbit Athena PROS ONLYRe: Gorilla Steve Gorilla Steve 11/16/10 04:51PM
  Re: FS: Hobbit Athena PROS ONLYRe: rock finally shredding pow rock finally shredding pow 11/16/10 05:40PM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/16/10 07:24PM
  Re: FS: Hobbit Athena PROS ONLYRe: rock finally shredding pow rock finally shredding pow 11/16/10 07:58PM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/16/10 08:03PM
  Re: FS: Hobbit Athena PROS ONLYRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 11/16/10 09:19PM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/16/10 11:01PM
  Re: FS: Hobbit Athena PROS ONLYRe: Chris HnRz Chris HnRz 11/16/10 11:55PM
  Re: FS: Hobbit Athena PROS ONLYRe: Uphill DarthNater Uphill DarthNater 11/17/10 12:36AM
  Re: FS: Hobbit Athena PROS ONLYRe: Ryan Hawkins Ryan Hawkins 11/17/10 11:01AM
  Re: FS: Hobbit Athena PROS ONLYRe: campeona del mundo campeona del mundo 11/17/10 12:28PM
  Re: FS: Hobbit Athena PROS ONLYRe: justin justin 11/17/10 12:37PM
  Re: FS: Hobbit Athena PROS ONLYRe: Peter Peter 11/17/10 01:19PM
  Re: FS: Hobbit Athena PROS ONLYRe: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 11/17/10 02:52PM
  Re: FS: Hobbit Athena PROS ONLYRe: Peter Peter 11/18/10 12:33PM
  Re: FS: Hobbit Athena PROS ONLYRe: Tate in Madison Tate in Madison 11/20/10 09:25PM
  Re: FS: Hobbit Athena PROS ONLYRe: rock no longer shredding pow rock no longer shredding pow 11/21/10 01:45AM
  Re: FS: Hobbit Athena PROS ONLYRe: cool guy cam cool guy cam 11/21/10 02:28AM
  Re: FS: Hobbit Athena PROS ONLYRe: peter peter 11/22/10 10:50AM
  Re: FS: Hobbit Athena PROS ONLYRe: Peter Peter 11/23/10 07:26PM
  Re: FS: Hobbit Athena PROS ONLYRe: Ryan P Ryan P 11/23/10 08:45PM
  Re: FS: Hobbit Athena PROS ONLYRe: Matt Bengry Matt Bengry 11/23/10 11:51PM
