These ain't your papa's EBR forks...
FS: Showa hydraulic forks with AJP disc brake on a 3-star Grimeca shod with a 16" Metzeler. Forks are 27" long from center axle to bottom of top triple tree. Stem is 7.25" long and slightly (hair) more narrow in diameter than standard Puch, which means a Puch bottom race will drop right down. Triple tree is fully adjustable (make them shorter if you wish). Comes with master cylinder control and one Domino grip. Fill up the brake fluid and hit the streets...
This set-up is considerably lighter than K10 forks and much better built than anything else I've seen (no pressed steel).
It would be totally rad on a 103, TSM, Magnum, Freespirit or ?
$385 shipped
Please...don't buy them! Buy the AM6 instead and I'll keep these for myself.
