25mm Tillotson HL360 Pumper-Carb FOR SALE
I am selling a very low miles used Tillotson HL360 Carburetor; 24 or 25mm depending which measurements you believe. Integrated fuel pump for continuous fuel flow and mountable at any angle. Uses no jets, just two range mixture screws for easy adjustment on the fly. Comes with gorgeous velocity stack. Retails for $109, FIRST REASONABLE OFFER ACCEPTED. Ships from 97232.
Josh.Griffith79 - at- gmail -dot - com
<a href="http://s52.photobucket.com/albums/g7/Diabolicalplan/?action=view&current=DSCF4973.jpg"; target="_blank"><img src="http://i52.photobucket.com/albums/g7/Diabolicalplan/DSCF4973.jpg"; border="0" alt="Photobucket"></a>
Re: 25mm Tillotson HL360 Pumper-Carb FOR SALE
You mean mountable at any angle as long as it's upside down. I have this carb and it ONLY runs upside down. I even bought a complete pop-off spring kit. My motor had a pretty strong pulse and I tried every spring and spacer setting. Gas would only flow if the pump was on top. After further research I discovered that the kart racing guys use electric fuel pumps to push the fuel through these.
Your price is good. Someone should grab this.
Tate in Madison /
I might get this for my sno runner.
I need to check and see if it is compatible.
bump.
bump.
Do you still have this carb for sale. And what will you take for it?
Thank you,
Rich
emailed!
I would like to try this beast. You would need a pop off gauge to set it up best. You have any use for a Moby CDI or HC head as trade?
Moby HC head or other marque?
I am curious about the center to center stud measurement. I've wondered if these could be adapted to a smallframe Vespa, but never had one handy to mock up. Would you be willing to measure for me?
HeyZeus Oak /
Where can one even buy these new?
I will send you pics later this evening Josh after my mini trip. I am not sure what head it is, I am not really a Moby guy. I got my 50v together and it goes 40 plus stock so I didn't use the ignition or head. The ignition is brand new while the head is slightly used.
Reading up on these carbs I saw that you need to make some kind of pulse line from your case to the carb, also that they really only work well at wot. Really want to play with one for a race bike... They sell them new at various online retailers, or perhaps your local motorsports shop... Wish I needed it now, great price!
Scooter Marc: the center to center stud distance is 46mm.
Garry: I bought mine through Reiken's /Out2win.com, but a well-equipped lawnmower/chainsaw repair shop may be able to help.
HeyZeus Oak /
I got $60 shipped????
