WTB: Morini bits
So, I'm lookin' for some pretty specific M02 bits, specifically:
The starter clutch engagement bearings
The two nuts that bolt onto the crankshaft and the pinion shaft inside the crankcase
The hex nut like thing that you hold with a crescent wrench to remove the first nut off the crank shaft (pic forthcoming)
and the nut that holds the flywheel on.
email me, I guess
Re: WTB: Morini bits
Nobody has a morini parts engine? Fo' reals?
I've got 2 1/2 engines, so I can look at my "1/2" engine and see if I have what you need. I'm pretty sure that I have the nuts you want, but I dont think I have a third set of the bearings. Check out ebay france or ebay italy - you may get lucky for that stuff. I'll check next time I head out to the garage and see what I've got for you.
