FS: Garelli NOI engine
This is a used engine,
The case is broke, right where some stuck a screwdriver to get the sprocket nut off the output shaft.
Engine will need crankshaft main bearings also the connecting rod play is over the limit of toleance. The crankshaft wheels are fine. Clutch rubber is og one. The rubber clutch grommets are in good shape! I can't push or pull the crank side to side..I have the ignition for the engine it is in mint shape with the woodruff key. so that's the good things about the engine.
The rest of the parts also are in a+ condition.
So if you have a kitted garelli should try to pick up a spare bottom end.. for parts.
Please make a offer no trades.
