WTB Derbi crankshaft
I have a relay relay clean tt that has a bad crank help me out pleas
Re: WTB Derbi crankshaft
Do you mean really or is you ignorant
if its a piston port...you should find someone to press apart your crank and replace the con rod...not lots of pp cranks out there right now.
does a puch rod kit work?
Derbi piston port stated crank stroke is 43mm
bore is 38mm
its not the road that goos bade its the crank its self is a thow under sizes on one side so it will walk
loctite bearing retainer..
has worked wonders.
green stuff
my translation is.........its crank throw undersizes on one side
and makes the crank walk
tons of them are like that. use bearing locktite. yes, it's not the best solution but those cranks are rare as fuck.
Joey.. we may see them.. oneday when were old..cheers
