FS: Honda NC50 Express Parts
Honda Express NC50 parts: 1977-81
1 Front brake cable
1 front wheel hub with pads
1 wiring harness/2 flashers from a 1980
1 wiring harness from a 1977
2 or 3 flywheel covers
1 blue fork assembly
1 yellow fork assembly
2 wind-up starters/recoil assemblies $50 each
1 set of wheels in decent shape
1 exhaust shield
1 working horn
1 complete stator assembly with flywheel
1 speedometer cable
2 shocks
2 stands
3 good running engines without wind up starters or stators
Located in NY
MAKE OFFERS! stuff has gotta go
Re: FS: Honda NC50 Express Parts
hey man do you have any gas caps or speedo cables by any chance?
Thanks,
G
no gas caps but I do have a speedo cable in great shape
email me kawasaki19771@yahoo.com
thanks
make offers on anything or everything
bump
Matthew Chedda /
Got an NU50 motor?
I have a speedometer cabel for you, e-mail me at: redbarron89@msn.com
hows the muffler shield? is it damaged anywhere? Do BOTH flashers work? I'd be interested in those, please respond: redbarron89@msn.com
Please tell you have an air filter you forgot to highlight.....
please....
how much for a piston shipped to Portland or
I have 1 1977 NC50 engine with a broken kick starter spring and 2 1980 NC50 engines without side covers, not sure if they are the same as the nu50 ?
muffler shield needs paint, i think theres a dent on it also.
atleast 1 of the 2 blinkers should work
I've got a 1977 Honda Express. Looking for a carb for it. Any suggestions? Not finding much. A good used carb will do. My uncle is fixing it now, but the bowl (?) has corroded and is leaking through. He called me in desperation to see if I could check the internet :). So, anyone with a good used carb, or any ideas where to get parts, or suggestions on replacement carbs for my mom's scooter? Thanks!
