batavus spare parts lot
batavus parts lot (w/spare parts catalogue)
Laura m-48:
clutch component, locking plate (2)
new old stock drive belt (2)
starter spring arm (2)
clutch pressure spring (7)
newfren clutch plate
cylinder stud (3)
clutch end plate [orig. pkg.] (2)
threaded bar support plate for clutch arm (4)
motion left mopeds custom intake [allows for 15mm dell'orto]
Laura m-56:
starter plate
Batavus HS 50/VA:
brake shoes (2)
brake plate
rear brake cable
various paper gaskets (30) approx.
carb idle screws (3)
dust ring [front wheel assembly] (7)
rear wheel assembly cup (2)
rubber lined washers w/spring [gas/oil seal ??] (21)
13 tooth sprocket
springs [pt. no. 48-174-07] (5)
dust ring [rear wheel assembly]
3/16" cable stop set
intake silencer [unopened orig. factory pkg.] (2)
head lamp interior fitting (3)
wrap around fastener assembly (4)
rubber carb seal (3)
magura brake lever (4)
3'8"/ 87 link pedal chain
head lamp interior assembly (5)
needle bearing (10)
washer [pt. no. 48-150-05]
washer [pt. no. 48-0887]
headlight assembly speedo/tach cover (5)
front fork dust bellows (3)
exhaust silencer [inner & rear]
magura clutch/start lever (6)
crank assembly dust protectors (2)
chain tensioner assembly
rear spindle assembly (2)
brake shoe spring (4)
headlight control w/cable (3)
air filters (5)
under carriage splash guards (2)
20 tooth rear free-wheel (2)
front fork nut, spacer & lock ring (3 sets)
gudgeon pin (4)
clips---^ (50 approx.)
front wheel spindle cones
front head lamp external housing
pedal w/crank (2)
gas cap (unused)
pedal chain master links (16) [approx. 10 still in sealed packaging]
rubber engine cover strap (15)
pedal cranks (2)
pedal crank bushing (2)
brake shoes
rear wheel chain tensioner (3)
i have pictures of everything if you are interested email me and i'll send em.
looking to sell everything together for $150. the new old stock clutch parts and brake components will retail for more than that alone. everything is in individual bags labeled with corresponding catalogue part no. many parts are in original laura motors packaging/never opened.
will ship. whiskey business delivery option. buy with bronco and regency in that other post for $550 total.
Re: batavus spare parts lot
how much for the motion left custom intake for a 15mm dell'orto for m48 seperate?
Interested in the exhaust components for the HS50.
Tony montana /
m48 custom intake for me please, shipped to 43014?
Hi,
Do you still have the chain tensioner available? If so, how much do you want for it?
Thanks,
David
Is this what you have see attch. ?
I need it for a 77 batavus moped
Ya still have batavus parts ?
I need A starter arm
I'm looking for a pedal chain tension wheel for an 1981 Batavus. I have tried Moped Junkyard and haven't had any luck.
I have attached a picture of the part.
If you know where I can get BATAVUS parts please contact me.
Little Colonel
i need a pedal shaft. the part that goes through the frame for a starflite m48 let me know. will also e-mail
Kendall Warnock /
Hey bro, let me know if you still have all of this. Email me at kw_23@hotmail.com I may take it all.
Kendall
Looking for pin that goes to the carbortator and a carbortator
