WTB:plastic riser for puchathena & MB5 4 petal
benji used to carry these.
want to pay like 20 shipped
Re: WTB:plastic riser for puchathena & MB5 4 p
i should still have one i am not using, it's your if i can find it at the shop tomorrow...if i don't, i know freddie is getting some in the next few weeks
How thick? Im out of the 1/2 ones but have plenty of the 1/4
im not entirely sure how thick, but my 4 pedal reed block will fit if i can bring it up a little, emailing both of you, and WB3?
~SABAT!
http://www.treatland.tv/plastic-riser-puch-athena-MB5-p/puch-athena-riser.htm
plastic riser for puch athena and honda MB5 4 petal reed modification. so you can use one of these and a gilardoni type reed block will fit in there. if you're using a malossi VL6 reed or something like that you may have to take off the reed stopper thing on one side to make it fit. the gilardoni block, polini block, doppler blocks and others need some dremeling to open up the mounting holes a bit.
this is for the athena AJH version ONLY. and works with all honda MB5 kits
i bet two 1/4ths will suffice?
found one, sent you a pm sabat
