Re: WTB: Bend my pipe?
mike park /
if you can, post a pic of your problem. most pipe mounting issues can be solved without bending, which isn't really ideal anyway (unless afterward you heat the whole pipe up very hot to anneal out stress fractures and then quench it to solidify the repair)
usually a clever bracket or compound connections of sturdy brackets does the trick
