Parts Needed (The Cleaner The Better)...
Maxi Pedal Arm Pins
Maxi Rear Axel Adjusters
Maxi 12mm Rear Axle With Cups And Everything Else
Maxi Pedal Chain Tensioner
Magnum Pedal Arms
Thanks
Maxi Pedal Arm Pins
Magnum Pedal Arms
Thanks
I have the pedal arm pins, the axle adjusters, and the chain tensioner. 35 dollars shipped for all
i have this frame that you could take parts off?
