PUCH STUFF FS!
Ok i have a box of used ZA50 stuff.
4 mostly complete motors (ZA50) unsure of internal condition. will sell in order if condition from best to least. i know one is complete and turns. price negotiable.
box of heads and cylinders i think 4 cylinders and 5 heads pretty sure they are all usable..
2 sets of magnum forks one is in decent shape not bent i t dont think with bars other has bent headlight mounts but is still usable. both silver.
will trade for a good set of chrome rear maxi shocks or maybe mag wheels. let me know what you have and i might want it.
will take pictures and answer any questions on request. i have a whole box of other stuff to go through so ill add tomorrow if i can get to the shop.
post here or e-mail i check both often.
PUCH STUFF FS!
emailed
Re: PUCH STUFF FS!
emailed.
Re: PUCH STUFF FS!
im going to be taking apart one of the motors so if you need anything besides a crank and a first gear drive gear let me know and ill see what i can do.
Re: PUCH STUFF FS!
Let me know if the stator looks good and you think it will work.
Re: PUCH STUFF FS!
disregard last message unless a ZA50 stator will work on a E50
Re: PUCH STUFF FS!
"pics are here. tell me what you think you might want and we can talk about a price.":http://s285.photobucket.com/albums/ll71/ttlx2001/
Re: PUCH STUFF FS!
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.pbsrc.com/flash/rss_slideshow.swf"; flashvars="rssFeed=http%3A%2F%2Ffeed285.photobucket.com%2Falbums%2Fll71%2Fttlx2001%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1"; target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_geturs.gif"; style="border:none;" /></a><a href="http://s285.photobucket.com/albums/ll71/ttlx2001/"; target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_viewall.gif"; style="border:none;" /></a></div>
try that...
Re: PUCH STUFF FS!
Derek L TYTYTY /
Pic 8, is that an ignition coil?
Re: PUCH STUFF FS!
17 is gonna be parted out i think its gears are totally fucked.
14 isnt that bad it could be honed out ok. rings are stuck in the piston tho and a clip is bent kinda funny
11's gear is pending.
10 might be spoken for
7: top left is a tomos i think its plastic. the one tot he right of that has no dents. a good sand blasting/ sanding and some paint and its good. the back is all rusty. the bottom left ring i think is for a moby.
6 the freewheel is for either a moby or peugot its made in france. says atom on it. works fine. not pictured i think i have magnum pedal shaft its longer than the rest.
5 those three black things are for puch speedo holder bottoms. idk what the story is about the white cover its cool tho.
2 kinda rusty but look sok inside. steel wool and it should be fine looking.
3 cover is shot but the pans good. no bolts
1 is the inside of 17. both gears stripped. turns over tho and the top end looks ok. same with the crank.
i think thats it. ask questions and ill try to answer im not very good with ZA50's
Re: PUCH STUFF FS!
yeah its a bosch if i remember correctly.
Re: PUCH STUFF FS!
What are you thinking for the better magnum forks?
They are the hydros correct?
Anything you need trade wise? How much cash?
Re: PUCH STUFF FS!
Also interested in an ok cylinder as long as it isn;t one of those tiny ported 1hp pieces.
Re: PUCH STUFF FS!
the good pair look ok and i didnt take pics of them yet they were in another shed. ill take a pic of those tomorrow for you. im not sure if they are hydro or not. they work pretty good very bouncy if i recall correctly. i could use some mags for a puch in decent shape maybe. e-mail me and we can work something out.
Re: PUCH STUFF FS!
Derek L TYTYTY /
Does it work? How much are you looking for?
Re: PUCH STUFF FS!
as of now it looks like three of the motors are spoken for and one is going to be parted out. ill update tomorrow.
Re: PUCH STUFF FS!
not sure if it works or not... any one know how to test one besides putting it on a bike? if its does end up working 10 shipped?
Re: PUCH STUFF FS!
Is the crank arm in the pic for the left side? If so, I'm interested.
Re: PUCH STUFF FS!
One complete motor left. Number 1 cylinder.swapped out its shot gears with a better pair. turns over fine.
One for parts. it has good cases and needs gears, gaskets, crank, and piston(clips,wristpin,rings...).
also have 2 stators
a couple mag covers
whole bunch of stuff. check the pics
<a href="http://s285.photobucket.com/albums/ll71/ttlx2001/?action=view&current=003.jpg"; target="_blank"><img src="http://i285.photobucket.com/albums/ll71/ttlx2001/003.jpg"; border="0" alt="Photobucket"></a>
good motor^
Re: PUCH STUFF FS!
! that?
Re: PUCH STUFF FS!
fuck. e-mail me for pics. 55 shipped. ill take parts from the other one too. if you want any.
