wtt:morini rings
DAM' Fairchild /
i have a rolling maxi frame less e-50, willing to trade for sum morini rings.i will post ring size later, or i would trade off a morini bottom end. or if sum 1 wants to give me a complete running morini, i would give them a puch,morini bottom end and brand new vespa kinetic polini pipe., hey i will even throw in a sebring frame and tank for the running morini.i would might even throw u a few other parts like a headlight,some handle bars or whatever is your delite.
Re: wtt:morini rings
DAM' Fairchild /
bump
good deal wtt:morini rings
DAM' Fairchild /
Re: good deal wtt:morini rings
I sent you an email, did you not get it?
Hey,
I have some stock morini rings from an M02 that I took off before I got a kit. I can trade you them if you have the clutch engagement bearing on your bottom end. Its the bearing that is attached to the transmission side case.
I have a nice piston out of a MO2 with rings. Steven
