WTB:maxi pedal crank
its for a pinto.
i just bought one from a guy on mopedarmy and he sent me one that had a stripped crank arm welded to it.
not what i need.
so if you have a maxi pedal crank that is in good shape...with out extra welds on it....let me know.
thanks
Re: WTB:maxi pedal crank
I think the pinto needs the wider two speed crank. Correct me if I'm wrong.
why would the diameter matter.....it is in direct relation to the frame and not engine.
i have a magnum crank in there and it is to long
I'm not talking about the diameter of the pedal shaft, but rather the length between the pedal arm points. I thnik the za50 maxis, free spirits, pintos, and swingers all use the same pedal crank - i.e. not the same one as the e50 maxi.
well i put the shitty one in there and its fine....thanks
ok i was wrong about this......novice move.
the crank arm is attatched to crank on maxi's....
i need one that isnt stripped and in good shape....thanks
the length appears to be fine,with the maxi crank
The arm is attached on one speed maxis. Anything from a two speed maxi to a magnum crank will do. So are you saying I was correct? Not looking to boost my ego, just want to know if my information is correct.
hey chance theres a maxi crankset on ebay for 5.99 right now.
hahaha that shit is 59.00
shit,nevermind i seen the 5.99 one
but there is one for 59.00
ill trade ya a maxi crank for that magnum one
hey i have a pair of pedal arms i'm taking off my pinto if you want them... i just got in some new ones so i don't need the stock ones anymore.
p
you should prolly just trade with me
not yet
