Part out Batavus, or blow up?
email me with what you want and offers shipped.
or paypal me 5 dollars so i can buy lots of black powder.
Re: Part out Batavus, or blow up?
justin.turner@comcast.net
hey dude is it ruunning? if so that's a shame. how much do you want for it?
its not running, i cleaned the carb and it has compression and it has spark but its just not working.
im trying to sell it for 200. I had to buy it in order to get a sweet maxi, so im out 200 bucks and im stuck with this stupid thing that nobody wants.
i want it, but i don't really want to pay anything for it. haha. good luck with it...i'll check around and see if i know someone who would want it.
I think you will be surprised how many people want parts off of that.
I had a pretty rough starflite top tank and over the course of 4-5 months pretty much everything found a home.
Batavi are my favorite parts bikes. The components are actually super nice. I like taking stuff off of them and using it on other bikes when I can because the parts are so high qual.
how much for the front fender??
why not use the frame and build something totally awesome with it?
how's the tank?
Build a Polini Puchavus.
is that pulley plastic or metal?
hows the tank and petcock?
If that's the 30 mph header il take that.
I'll take the carb too.
How many teeth are front and rear sprockets?
How many mph is the speedo?
man if u were on this coast id buy that right now
"its not running, i cleaned the carb and it has compression and it has spark but its just not working."
gas, compression, spark...if it has these 3 things it has no choice but to run. how good it runs tho varies. tune it up and ride.
hahaham,
i put a new spark plug in and some fresh gas and it started right up.
just because it has those 3 things it doesnt mean its going to work. waht about a bad seaL? plugged exhaust? bad timing...there are so many more things.
it will still run with all those things...just really shitty if anything else is messed up...like maybe a few seconds or only go super slow but it will run.
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
lolz!
it will still run? whats your definition of running?
onmgz
no your a big liar head, it will not run if the timings all off.
you can also have compression in the cylinder and such bad crank seals that it wont run. And like he said the exhaust....
its not just fuel fire and compression.
its fuel , fire , compression, correct timing, and a place for the motor to spit out what its trying to burn.
And a working condenser.
Amen to the working condenser. Damn mobys. hahah
🇮🇹💦 Of the Loin /
dude just give it to me. ill do a dance or something for you
it craves living with me
i say give it away or sell as a whole. looks pretty decent man... dont blow it up though. blow up old tv's or some shit nobody wants or wants to fix, a crt monitor. there ya go. blow up one of those. but see this little guy to a good home.
quit jumping down my throat people. all I was basically saying is that the ped supposedly had those three things and it wouldn't run and I found it puzzling. then a new spark plug and fresh gas and tada it decided to run. all other variables(bad seals, bent crank, plugged exhaust, what have you) would be factors of the ped running poorly or stalling out.
Timmy Southpark /
with a blown crank seal bikes tend not to run at all.
Im not sure what's going on with this bike with all the debating n whatnot but ill give you a solid 17$ for the pedal arms and pins if they function
Are you still parting this out if so ill give $30 for points and condensor
nerdzilla No mo Peds no mo /
i want the lever set and cables.
moped is gone.
