Re: FS 78 50v Seattle
Aaron Blair /
Motobecane mounts are a rubber donut so to speak. with an outer ring that friction fits into a hole in the frame and an inner ring that the bolt goes through, with rubber in between the two to dampen vibrations. Motobecane motors rotate on the mounts to allow the variator to open(transmission to shift gears) new mounts are available from Quarterkick.com or you could make a post in Buy/Sell. there not that hard to find
