Peugeot 102 & 103 parts
The time has come to part out my 102... I also have a reed block and case for a 103.
Here are the pictures:
50cc 102 Parmakit
50cc kit that I never got to install since it needs a custom intake. I don't have the piston for this cylinder, but I think the replacement 50cc polini piston from Treats might work. Maybe even stock, who knows. This thing is ported to shit, and it needs reeds to really work, as it has 360 degree intake timing. Booster ports above the intake and eyebrow transfers
Ported 102 case and 102 crank
The case is matched to a ported stock 102 cylinder, not the Parmakit I'm selling. Needs new seals. The crank is fine, a little dirty but I never had problems with it. Includes the needle bearing. Case also comes with hardware and mounting brackets
Stock 102 head w/ decompression valve
Stock head sanded down a little for higher compression, comes with decompression valve
102 clutch and 5 coil stator
Yep, I have that 5 coil you're looking for. Buy it now please. Has new points and condenser, but I'll include the original condenser and points anyway. The clutch works fine, I put in a new clutch pad a little while ago
Stock 102 pipe
Not much to be said, it works
Ninja Warm Up exhaust
Worked great on my 102, I had a little threaded mount welded over the ball joint so it threads into 102 cylinders just fine. I only have part of the mounting hardware, so... have fun with that. Restrictor removed, also has some scrapes from coming a liiiittle too close to a curb
Polini SHA reed block for 103
Everything is there, never used, the block itself is dremeled out a little bit to match the gasket and case
103 Stock budget case
Brand new, comes with 3rd transfer. Includes studs, hardware, bearings, and seals already installed. The intake is matched to the reed block I'm selling above
Make some offers
and Merry Christmas you bastards
Re: Peugeot 102 & 103 parts
Wow, fuck me right?
Here are the RIGHT pictures
102 case and crank:
5 coil and clutch:
Stock exhaust:
Emailed about the 5 coil. I'm in sac too, so I can come it up.
emailed about 103 stuff
Holding the 103 case and reed block for Jacob, and Dan has dibs on the 5 coil until he says otherwise, but nothing is actually sold yet.
I also have a blue dual exhaust that I never used
Don't be afraid to lowball for anything, I'm just looking to get these things gone quick...
Email me with how much for pipe
The ninja or the dual exhaust?
The dual
how much for the 102 case and crank....
$35 shipped for the 102 case and crank sound good?
you got a stock variator kickin around?
Nope, no variator
103 case and reeds still available, along with everything else except the 5 coil, which I'm holding until tomorrow
