Wanted e50 motor or bottom end!
I need a running e50 motor for my maxi or an e50 bottom end that is together and able to have a cylinder and head put on and run. Possibly near ri/mass would be great! Thanks!
Re: Wanted e50 motor or bottom end!
Probably Fred /
Do you need a carb, intake, air box and pipe? do you need the electronic parts ( stator, coil and plug wire and cap, flywheel) and magneto cover? do you need the bolts to bolt the engine to the frame. Do you need a 2hp topend ?Do you need a tuned clutch with thick springs? Email me with all you need Thanks
I have a few motors from just case halfs and a main gear, to a complete rebuilt stock motor, to a custom kitted motor. Send me an email with your price range and what parts are important to you.
