FS/FT- Last of my Puch parts!
Ok, so I'm down to just this stuff. I'm putting all my interest into my pinto and have no need for all this extra stuff anymore. I'll try and name out most of the items, with prices (since people don't like to make offers). If you don't like the price, shoot me an email and we can work something out. The more you buy the more I'm willing to deal!! Also, should mention that prices listed DO NOT include shipping.
-19mm PHBG spigot mount clone w/ 2 airfilters - $40
- 1.5 sport seat (needs recovered) w/ post - $25
- 15mm sha treats intake - $12
- handlebar clamps w/screws - $7
- Vespa 12.10 Del carb w/ airbox - $20
- Puch 14mm intakes (one round, one square) - $10
- 40mph speedo (needs put back in housing) - $20
- Coil - $20
- triple tree plate - $10
- NOS chain tensioner - $10
- NOS Lelu brake plate - $10
- 2 speed sidecovers (coil area opened up more) - $15
- Maxi sidecovers (nice w/ screws) - $25
- Handlebars - $5
- Cylinders w/out piston - $10 each
- 1 Cylinder with piston/good rings - $25
- Cylinder heads - $7 each
- horns - $4
- Vepsa bullet headlight w/ 40mph speedo - $25
- Caio sidecovers (some small cracks) - $5
- Pistons w/out rings - $5 each
- Domino throttle assembly - $10
- Maxi pedal crank assemblies (some need pedal arm straightened) - $10 each
- Pedal arms - $4 each
- Pinto seat (obviously needs covered) - $5
- Pinto kickstands - $10 each
- Kickstand spring - $4
- 2 speed speedo - $10
- Maxi stock airbox - $3
- Maxi wire covers - $2 each
- Mirror - $1
- Pinto airbox part - $2
- Magura throttle assembly (missing brake handle) - $10
- Pinto headlight bucket - $3
- Grips - $5
- Box of bings/intakes (there's a ton of them) - $50
- e50 bottom end w/ electrics/coil - $60
- Nice flywheel cover $10
- Brand new longseat - $43
- Pair of forks (need work or for parts) - $20
Like I said, offer up on multiple parts!!
Re: FS/FT- Last of my Puch parts!
Damn, it didn't put spaces like I wanted.
-19mm PHBG spigot mount clone w/ 2 airfilters – $40
– 1.5 sport seat (needs recovered) w/ post – $25
– 15mm sha treats intake – $12
– handlebar clamps w/screws – $7
– Vespa 12.10 Del carb w/ airbox – $20
– Puch 14mm intakes (one round, one square) – $10
– 40mph speedo (needs put back in housing) – $20
– Coil – $20
– triple tree plate – $10
– NOS chain tensioner – $10
– NOS Lelu brake plate – $10
– 2 speed sidecovers (coil area opened up more) – $15
– Maxi sidecovers (nice w/ screws) – $25
– Handlebars – $5
– Cylinders w/out piston – $10 each
– 1 Cylinder with piston/good rings – $25
– Cylinder heads – $7 each
– horns – $4
– Vepsa bullet headlight w/ 40mph speedo – $25
– Caio sidecovers (some small cracks) – $5
– Pistons w/out rings – $5 each
– Domino throttle assembly – $10
– Maxi pedal crank assemblies (some need pedal arm straightened) – $10 each
– Pedal arms – $4 each
– Pinto seat (obviously needs covered) – $5
– Pinto kickstands – $10 each
– Kickstand spring – $4
– 2 speed speedo – $10
– Maxi stock airbox – $3
– Maxi wire covers – $2 each
– Mirror – $1
– Pinto airbox part – $2
– Magura throttle assembly (missing brake handle) – $10
– Pinto headlight bucket – $3
– Grips – $5
– Box of bings/intakes (there’s a ton of them) – $50
– e50 bottom end w/ electrics/coil – $60
– Nice flywheel cover $10
– Brand new longseat – $43
– Pair of forks (need work or for parts) – $20
Hopefully this works so it's easier to read.
Will that brake plate work with a Puch Snowflake front Wheel?
- Joe
No clue, up to you to check it out.
Parts on hold for a few days for someone's funds to clear - e50 bottom end, 19mm phbg, set of handlebar clamps.
All others are still available.
I'd like the phbg clone and airfilters
will the long seat fit a newport II if so how much to ship it 2 sunny fl
It's a maxi longseat (bought from mopedrecyclers and treats has the same). It should fit no problem. Email me your zip and I'll get a quote. Seat was put on my maxi for 2 minutes, then removed, so the seat post has a couple marks on it.
zip is 33952 thats my moms im in the middle of a move
Pablo Puchasso /
Could I get two clean pedal arms? Email me your paypal.
Hey Max,
The two pedal arms that are there definitely have some pitting. I don't have any real nice ones.
Stinger - I'll get back to you asap.
Also thought I'd mention that I would trade any of this stuff for a different proformance pipe for my pinto other than a Simo. I have a simo on there now, but still doesn't let me use pedals even with a Magnum pedal shaft. Anything would work (boss, 4p, estoril, etc), just not really into the proma pipes. I'd even throw some cash in if needed. (or trade my magnum pedal shaft with some parts for your pipe)
Ok...Ok...I will trade you my used black Techno Boss for your Magnum pedal assembly(complete), the chain tensioner pictured above, and a 15 Bing(if you have a complete one in that box)......I can even give the Boss a fresh coat of High Temp. Black Grill paint and throw in a new Exhaust gasket when i ship it.
No thanks. A boss pipe is what, $60 plus shipping? For a nice magnum pedal shaft is 40-50ish, 10 for the NOS tensioner, plus a 15 bing that costs $88 plus shipping? (not to mention that I don't have one) Seriously?
I was talking about a used old Bing =$10 maybe $15
A chain tensioner= $10
And a used Magnum shaft = $40
I don't think i'm that far off.
- Joe
Hey Brian...Shoot me a couple pics of that 1.5 seat (side, bottom, etc). If it's something I want I'd knock some bucks off that Estoril.
emailing on the vespa headlight...
You said a 15 bing, not an old 12mm bing (that's in the box). MAJOR difference between a 12 and 15 bing.
Bukwheat, going out to take some pics right now!
Nic, get back to you asap about the headlight.
Just sent you 3 pics!
did u get my email?
Literally JUST replied to you buddy.
right back at ya...
Vespa headlight pending sale till tomorrow!
What about that phbg clone ya sold that yet?
I emailed you back earlier from your email and I posted that it was sold before you first posted here. Sorry.
You said "Box of bings/intakes (there’s a ton of them) – $50 " ....So i was only looking for 1 out of that "Ton" to be a 15mm,,,and i know that there is a difference between a 12mm and a 15mm....I have a bunch of 12's and no 15.
A simple "I don't have a 15m Bing in that box to trade" or " No thanks" would have been great.
- Joe
LOL. Ok Joe. Your offer was sort of rediculous. But thanks anyway.
Still a ton of parts left! I want all gone!
Well you didnt say it was sold on here... updating the list might let other buyers know whats avalible.
Check the 5th post down. Don't be a douche because you can't read.
Used Techno Boss with sweet thick yellow Gasket for the Magnum pedal crank assembly and the chain Tensioner?
- Joe
