WTB yamaha DT parts tach cable,blinkers,fast parts
hey guys
i just bought a 1988 yamaha DT 50 LC and there are a few parts i need for it
blinkers: the bike has a 6 volt system so im guessing any 6 volt blinkers will do
tach cable, the tachometer doesnt work and im pretty sure the cable us faulty
set of mirrors. because im going to register it as a bike it will need a set of mirrors
go fast parts...anything you got, big bore kit, matching carb, exhaust, reeds, methanol injection you name it
thanks alot guys :)
Re: WTB yamaha DT parts tach cable,blinkers,fast p
DT50s are pretty fast as is...i want one badly.
go to your local motorcycle shop for mirrors and turn signals, if you dont care about them being original yamaha equipment, i can pretty much guarantee theyll have something that will work fine.
thanks...the DT is a good starting ground but it is nowhere compared to the MTX and TSX i had in highschool
both of them run a 70 CC polini with a 22 on the honda and a 24 on the suzuki (both mikunis) and of cours homoet exhaust pipes
(back then i knew where to get parts)
both those bikes would run wel into the 70s AND pull the front up when downshifting into 3rd gear
that is pretty much where i want to end up with the DT
specially since the SOS made me register it as a motorcycle
took her out for the first time today
burried the needle which isnt saying much since the speedo only goes to 50 MPH
i think the bike hit about 54
not bad for bonestock but not where i need it too be just yet :)
