used for 20 miles, everything's perfect. stock setup with 92 jet, 40 slide, w7 needle, 60 idle, 55 pilot. install your choke setup of choice (cable or pull, not included). clamp style.
$80 shipped.
$80 shipped.
this is the as or ds, right? aka will work on my moby?
Hey mike, did you have this on your puch? I just got a 1977 maxi I am trying to fix, think this might work if you have an intake that would fit...
hi, it is the CS model...had it on my moby for a while with no problems, but the controls are on the opposite side for moby. austin, i have a similar carb on my puch...this would clamp right on an intake. i also have a malossi 4 petal reed valve for puch polini if you're going that route
