FS: peugeot malossi 70 kit sans piston
sans means without.
kits in good shape. has manybe 200 miles on it. aluminum. i opened up the cylinder sleeves, slight scuff on the inside from the piston dying (decomp leak=hole in piston)... not even really noticable.
75$? w/the salvaged rings from the piston!
will ship! >sf
i have a 70cc high comp head w/ decomp and decomp plug, i would also sell too
$35 w/plug! $30 w/out
or tell me what theyre worth to you.
Trade possibilities: stock peugeot engine. or doppler spring.
Re: FS: peugeot malossi 70 kit sans piston
Damn.... I was hoping you had a piston for that bad boy too. I have that same kit with a malossi 70cc head with plug for the decomp hole..... Same thing, blew a hole right threw the piston and marked up the cylinder the same way. The scuffs you can barely even feel so I can't imagine it would do anything ill to a new piston. Looks exactly like yours. Seems like those heads would be better if the hole was just welded shut with aluminum and then smoothed out on the inside.
yeah, i would slap some jb weld in the threads before i ran it again. hopefully seal it up good. its happened to a bunch of people.
the cylinder is perfectly fine, just giving full disclosure.
or best offer.
im moving soon, need $$$
bumo-tastic
do you still have this?
yes i do.
bump
