Honda PA50II parts for sale
http://img.photobucket.com/albums/v160/stampede_dude/hondahobbit.jpg
Here are the honda pa50II parts I have for sale. I bought this ped without a top end or carb to take parts from for my PA50II.
Bottom End: I have no idea if it ever ran or not. I wouldn't bank on it. Looks like someone tried and failed to take the clutch off.
In box: Throttle (Needs cable), horn, horn cover, frame half of the battery box on newer pa50s, screws.
Frame: Fork is locked up. Rear shocks work good.
Rear wheel: tire stays with me. Gearbox seems to work good.
I am willing to send these parts to people for more or less chump change as long as you pay shipping and at least somewhat of what it is worth. I don't need any of these parts and knowing how rare they are I don't want to throw them away just yet. I also have a speedo that is in nice condition but has condensation on the faceplate.
I would rather trade for these parts:
PA50II odometer cable
PA50II Rear Brake cable
Thanks!
Re: Honda PA50II parts for sale
Downhill Harvey (OFMC) /
How much for the rear wheel to 97214 Portland, Oregon?
I don't know, it will be without the tire as I mentioned. It will probably be somewhere around $20-$25 to ship it by UPS, and whatever it is worth to you on top of that.
Would you take $35 for the wheel/trans/pulley?
With or without shipping?
$40 with shipping.
I can do that. Do you do paypal?
email sent
Rear wheel is sold
How much for the variator/ramp plate assembly from the bottom end? Shipped to 68510...
Thanks.
Make me an offer. It looks like someone might have tried unsuccesfully to take of the silver nut on the end, I don't know. I posted a high res picture. I don't know how to remove it, unless there's a trick to it I won't be able to take it off.
I also found a front turn signal bar. Mine doesn't have it. I can put a good lens on it. If it is bent it is only slight and not noticeable. I don't know about the bulbs.
I would like the ramp plate shipped to 44125, if you have an impact socket big enough that would be the best bet, i need that plate to finish my build.
Thank you.
will do paypal instantly.
Archie check your mail. The rollers in the variator are trashed.
what do you want for the whole motor with the vario shipped to 85208?mesa az
Sorry, I have the engine torn down, I sold the ramp plate off of it already and one of the rollers in the vario were broken, sorry.
based on the wiring, thats a CDI motor.
Got a pedal shaft/pedal cranks?
how much for the engine cases and crank?
Brandon Bakke /
My name is Brandon B too!
Free bump, lol.
I just got my wheel. That was fast and I especially liked the note on top of the box:
ATTENTION CARRIER
This item is fragile like glass
Please do not sit anything on top of it.
You wouldn't happen to have a set of PA50 I variator weights?
How much for the seat pan shipped to 55428? Thanks!
Seat pan I can do $15 shipped via Parcel Post.
Harvey, I now have a pedal shaft but I don't know if the pedal cranks are bent or not. Shoot me an email if you would both of you.
Do you have a stator assembly for it?
How much for the battery, wiring and flywheel+stator?
I have the flywheel, and a good stator, maybe two good stators but I have to remove them first, which will take a few days because I need an impact wrench to split the crankcase. The battery I assumed was no good, price on it would be $5+shipping. I have the flywheel in mint condition, $10 plus shipping for it. I also have parts that people have already asked for above, but I would ask that you would all email me because I don't check this part of the forum much.
Thanks,
Brandon
Do you have a crank?
Nope, sorry.
Emailed you
