WTB: puch maxi fork spring threaded coupling
mopedcrankworks.com - /
I need one of these parts: it is item #22 in the picture and is called a Top Threading Coupling. One of mine is stripped and the fork nut will not tighten. If you have an assembly of parts 19 thru 22, I would likely buy that too.
Re: WTB: puch maxi fork spring threaded coupling
I have a few janky sets of forks, I'm sure there's more than what you need. There's three sets to be exact. I'm in Toledo, don't know where in Ohio you are, but I'd make you a deal if you wanted to pick them up.
Yeah, I'm close to the Ohio river. Too far to drive to pick up. Don't know if you'd be will to yank a spring assembly out of one of those fork tubes and ship it. If not, it's cool.
wow, i just had that same problem. thanks alot for posting that diagram. i might try to tap the thread, do you think that would work?
With a matching bolt, I don't see why not.
