FS Dellorto SHA 15 carb
mike park /
$35 shipped.
Cable choke screw insert broke off inside the threaded cable insert. Tried unscrewing broken part, but still stuck; may come out with grease and effort.
Carb used for less than 30 miles.
Works perfectly, just choke cable insert needs to be removed or replaced.
Use as is (if you don't need the choke function) or you could buy just the body
http://www.treatland.tv/dellorto-SHA-15mm-cable-carburetor-body-p/dellorto-sha-15-cable-body.htm
and you would have an essentially new carburetor.
a 68 or 70 main jet is inside.
email if interested.
