WTS: Puch EUROSTYLE conversion kickstarter kit
Oo o my .. can you say ... from a treasure box.. :)
How many times you seen these O jeez.. you say .. I wish I could make my pedal a kick-start.. well here you go.. silly kidos. Sweetness Puch EUROSTYLE conversion kickstarter kit..
If you want both black and pink.. add $15.. yay mismatch sew rad..
$90 free ground shipping in the lower 48 states !!
Hit me up with a email.
Thanks, Ed
Re: WTS: Puch EUROSTYLE conversion kickstarter kit
Hmm .... Interesting . How does it work ? Looks like this assy replaces the pedal shaft . Has a built-in one-way freewheel . But my question is where do you run the chain ??
Hmmm .:)
Remove the pedals.
Install conversion kit.
You use you pedal chain..
Most likely need a longer one.. maybe..
The pedals connect to the rear wheel - freewheel on the wheel . This drives the engine drive chain to the internal cable clutch. When the cable clutch is pulled it links the moving drive chain to the crankshaft thus spinning the engine over. Your adapter would have to go between the engine and rearwheel requiring (2) sprockets as well as pulling in the clutch to start. In any case - still can't quite figure out how you would use your adapter with only a single sprocket. Ideas ??
Nevermind , I got it. You need to start it on the center stand - Duh . Also the kickstart pivots forward like the original .
the human house /
i painted my one pedal pink . and took off the other.
.94 cents is all it cost
Pablo Puchasso /
That's pretty cool.
It ain't about being cheap.. Its about style kido :)
the human house /
im joking . i dont even have a pedal chain.
