complete E50 good runner
this an E50 I had all apart, cleaned & inspected everything & re assembled
the bearings & seals are used but in really good shape
the treat kit has less then 50 miles on it & the head has been shaved .030 the points are cleaned & set, so is the timing
the engine runs & sounds flawless Id like to get $275 or so but Im open
the bike I built is hard to ride & I need something more vertical like a morini engine or something I can mount lower without having to stretch the frame out
take care
JAK
Re: complete E50 good runner
what the hell is that thing in???? post a pic of the whole bike please
here is a pic of the scooter :-)
take care
JAK
Are you unable to see the pic I posted?
kool bike!
i would love one like that with 20in wheels
yeah I was thinking maybe a 24 inch wheel bike
dual suspension
the horisontal engine requires the engine to be mounted high in the frame
Id like to make the whole frame
I picked up a motobecane frame at the scrap yard for $10 & that thing dident really seem more stout then a bicycle accept maybe the wheels & brakes
you all take care
JAK
yea 24 in would fit me perfect
I have it on ebay & this is what I wrote there
take care
JAK
this is a Puch E50 Ive had it completeley apart & the clutch, bearings,seals & gears are all in excelent condition
the cylinder is an upgraded 50CC kit from treats.
the kit has 50 miles on it or less not broken in.... really
the engine runs awesome & has all the electricals intact, points cleaned & set timing set
comes with the ignition coil but not the carb although we can work that out
its a 20mm carb setup a tad rich for break in. its a good tight engine ready to go
I built this bike for myself & I really need an engine with a more vertical cylinder to make what I want
the horizontal setup makes the bike top heavy & the bike rides crappy so Im selling the engine
maybe at another time Ill build another one with a Morini engine
when I take the engine off Ill clean it up really good & drain the oil from the "trans"
box it up niceley & UPS ground it
if "bump " means to put it back to the front thats what Im doing :-)
have a great weekend
JAK
