WTB: Morini 15mm intake
I need a 15mm intake for my morini MO2 engine, for a dellorto carb.. where the F can i get one? i've searched everywhere.. someone help
Re: WTB: Morini 15mm intake
I can make you a 19mm intake for your kit. Ed
bTW, they don't make one. You are using a kit that is not made anymore super duper nice btw. Yea have to make it.
Here is a intake I made for a m1 same... as the reeedvalve kit.
there is no kit. my engine is stock, i'm just putting on a bigger carb and need a bigger intake to match
They don't make one. Its just that easy. Not that I have never seen.
The mo2's I have in my shop right now had 7/8mm intake with a 9mm carbs. The intake is offset bolting also another reason it has to be hand made. Good luck, I'll buy some if you find them.
none out there. you will have to drill yours out..
think the standard was 12mm inside diameter
I got a 14mm intake stock parts.
You can bore the stock intake out pretty close to like 13/14mm, I did to my GF's and another Morini I worked on.
Fill the dimple in the intake first with JBweld and let dry. Measure and mark the Drillbit to do intake side, use dremmel to match the mount side to port/readcage.
þλ†Я¡¢k §¡§ΩИ /
Ed, how much for an intake? thanks for the cdi btw.
