WTB hobbit reed cage
need a hobbit reed cage for my express build.
in marion, ia
thx
Re: WTB hobbit reed cage
bump, still need this for my build..
i got the reeds.. cant put it together without this part yet.. sigh.. anyone?
You nee the single or double?
I might have reeds and intake (if needed) for you. I have to make sure I still have it.
dont think i need an intake, just the where the reeds hook to or whatever..
"dont think i need an intake, just the where the reeds hook to or whatever.."
Okay so do you need the 10mm reed body or the 12mm reed body? D
ahhh.. shit.. whatever IRE rick told me i needed.. lol.
"They should work with some modification . However the real issue is the opening size in the reeds . Its smaller then the pa50 II and urban opening . So smaller than ideal . Don't get me wrong you can run the stock reeds . The pa 50 II are huge in comparison . Nu 50 reeds need the case opened up the fit . or a spacer . I would use the Hobbit reeds . Reed cage that is . Then the ones you are looking at on treats will be much easier to fit And will no longer be a week point , rather a strong one . Do you have some to compare from other honda bikes . It would make perfect sence if you have some pa50II ,Nu50 , and nc50 reeds side by side . Check it out ."
