where to find puch polini base gasket?
I saw mopedwarehouse has the entire set for $20, that pretty steep.
I just need the basegasket. Are they coming in anywhere?
Couldn't find it at 1977, handybikes, quarterkick, treats etc
Re: where to find puch polini base gasket?
Just make one. Go to autozone and get some rubberized gasket material. Cut the material to a decent size to be cut down further. Measure the outside diameter of the piston skirt and cut a hole in the material with that diameter. Coat the sealing surface of the cylinder with oil and slide the cut circle over the skirt. Take the gasket off and cut the shape that the oil made on the base gasket. Use a hole punch for the stud holes. Done.
Email benji at treats he has them . 20 dollars is a ripoff. It is a 3 dollar gasket
Rubberized gasket, contact cement in the can, shoot on gasket. let dry and cut out. Same as neutral4x4, not measuring.
